Create trigger for AP bootstrapping
This article provides the steps to create a trigger for AP bootstrapping.
Navigate to the System-->Triggers page and click on Add new trigger.
Select type as "Device Event"
For the trigger condition select "Event Contains" -->Condition "matches" --> Reboot or bootstrap.
Select the group and folder to whUser-added imageich the trigger is to be applied.
Version history
Revision #:
1 of 1
Last update:
‎07-11-2014 03:57 PM
Updated by:
Labels (1)
Contributors
