Deployment circumstances under which RTLS will not work.
Q:
In AOS, under what deployment scenarios RTLS server communication may not work?
A:
When RTLS is configured, CAP/RAP communicates directly with the RTLS server.
RTLS will not work with current AOS with below deployments:
-    CPSEC is ENABLED
-    RTLS server is not routable from the RAP inner IP (irrespective of CPSEC)
When CPSEC is enabled both CAP/RAP falls under the role "sys-ap-role". This is a system default role which cannot be edited and as a result we cannot add any acl's to it so as to allow the traffic between the AP and the server.
With RAP in place(without CPSEC), it uses inner-ip to talk to RTLS server and if the ip is non-routable, then the communication breaks.
Version history
Revision #:
2 of 2
Last update:
‎11-25-2015 04:23 PM
Updated by:
Labels (1)
Contributors
