'Disaster-Recovery' feature on AOS 8.x
MVP
MVP
Q:
How can we rollback a bad configuration on a MD in AOS 8.x?
A:
AOS 8.x brings in a new feature - 'Disaster Recovery'. While configuring MD's there are chances that we end up saving wrong configuration.
For eg; while doing initial configuration of MD and we save the wrong mac-address MM. Once the MD boots up we cannot edit any changes as all the configuration is pushed from MM. In these kind of scenarios we can use the 'Disaster-Recovery' option instead of doing a 'write erase'.
Consider that during initial setup, a wrong IPSEC key was saved and MD was rebooted. Post reboot MD will fail to contact MM and no configuration sync will happen.
(A7030) *#show running-config | include master
Building Configuration...
masterip 10.17.164.237 ipsec aruba123456 interface vlan 1
(A7030) *#show switches
All Switches
IP Address    IPv6 Address  Name   Location          Type  Model      Version
10.17.169.71  2001::1       A7030  Building1.floor1  MD    Aruba7030  8.0.1.0_57204
(A7030) *#configure terminal
This controller is managed by a Mobility Master.
Configuration changes can only be performed on the Mobility Master.
'write erase' is an option that can be tried. To avoid un-necessary re-configuration of the controller post 'write erase', we can use the 'disaster-recovery' feature as shown below:
(A7030) *#disaster-recovery on
Entering disaster recovery mode
(DR-Mode) *[mm] (config) #show switches
All Switches
IP Address    IPv6 Address  Name   Location          Type  Model      Version        Status  Configuration State
10.17.169.71  2001::1       A7030  Building1.floor1  MD    Aruba7030  8.0.1.0_57204  up      CONFIG DISASTER RECOVERY
(DR-Mode) *[mm] #configure terminal
Enter Configuration commands, one per line. End with CNTL/Z
(DR-Mode) *[mm] (config) #masterip 10.17.164.237 ipsec aruba123 interface vlan 1
Change in the masterip configuration requires device to reload.
Make sure the modified configuration ensures connectivity to the Master.
Do you want to continue [y/n]: y
(DR-Mode) *[mm] (config) #write memory
Saving Configuration...
(DR-Mode) *[mm] #show running-config | include master
(DR-Mode) *[mm] #disaster-recovery off
All Switches
10.17.169.71  2001::1       A7030  Building1.floor1  MD    Aruba7030  8.0.1.0_57204  up      CONFIG PROPAGATION
Total Switches:1
Once 'disaster-recovery' is turned 'off', MD performs a full-sync with MM and resumes configuration sync.
Version history
Revision #:
1 of 1
Last update:
‎03-17-2017 03:27 PM
Updated by:
