Do all versions of ArubaOS support EAP Offload for 2048-bit certificates?
Product and Software: This article applies to all ArubaOS versions.
If you are running ArubaOS 6.1 or later, you may use a certificate with a 2048-bit key for any purpose.
If you are running any release before ArubaOS 6.1, 802.1X EAP termination supports only 1024-bit keys.
From ArubaOS 6.1, EAP Offload for 2048-bit certificates is supported.
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 06:05 PM
Updated by:
Labels (1)
Contributors
