Do we support dual-nat and Is there a way to dual-nat to external host without the "ip nat inside" option on controller?
Environment : Any typical environment for the usage of both src-nat and dst-nat functionality
Yes. Dual-nat performs both source and destination NAT on packets matching the rule.
Forward packets from source network to destination; re-mark them with destination IP of the target network. This action functions in tunnel/decrypt-tunnel forwarding mode. User should configure the NAT pool in the controller.
When using "dual-nat", only the source NAT pool can be specified. However is there a way to dual-nat to external host without the "ip nat inside" option?
(Test-Lab) (config-sess-guest-web)#user any tcp 80 dual-nat pool test-pool ?
<0-65535>               Destination NAT port number
blacklist               Blacklist user if ACL gets applied
disable-scanning        Pause ARM scanning while traffic is present
dot1p-priority          Assign 802.1p priority
log                     Log if ACL gets applied
mirror                  Mirror all session packets to datapath or remote
                        destination
position                Filter position. Default is last. 1 is first.
queue                   Assign queue priority of the flow
time-range              Configure time range
tos                     Set TOS in ip header
<cr>
Yes; When using "dst-nat" there is an opportunity to specify the destination IP.
(Test-Lab) (config-sess-guest-web)#user any tcp 80 dst-nat ?
ip                      Destination NAT IP address
                        destination
<cr>
The destination ip is defined under the nat pool for dual-nat operation:
ip NAT pool <pool-name> <start-of-src-pool> <end-of-src-pool> <dst-nat-ip>
For example:
(Test-Lab) #conf term ip NAT pool arubatest 10.1.1.2 10.1.1.2 172.16.1.1
(Test-Lab) #show ip nat pool
NAT Pools
Name          Start IP         End IP           DNAT IP
Arubatest    10.1.1.2         10.1.1.2          172.16.1.1
Version history
Revision #:
1 of 1
Last update:
‎04-09-2015 04:35 AM
Updated by:
Labels (1)
Contributors
