Does 7005 controller support redundant power sources using PoE and DC adapter?
Q:
Will the 7005 controller reboot if the power source is switched from PoE to DC adapter and vice versa?
A:
Aruba 7005 controller supports redundant power sources.
The POE power source has priority over the DC source for 7005.
The controller should not reboot when power is switched, as per design
Version history
Revision #:
2 of 2
Last update:
‎02-10-2016 11:14 AM
Updated by:
Labels (1)
Contributors
