Does AP-135 negotiate power using lldp?
Environment : This article is applies to Aruba OS 6.1 and above.
In the Aruba OS 6.1, LLDP is not supported for Aruba AP's.
Starting from Aruba OS 6.2, LLDP support has been added for Aruba AP's.
To check the power negotiated by the AP using LLDP protocol execute the command show ap debug system-status ap-name <AP Name>.
Under Power Status,  LLDP Negotiated POE Power displays the power negotiated by the LLDP protocol.
Below is the sample output from show ap debug system-status ap-name <AP Name> and in the case, AP didn't negotiate power using LLDP.
Power Status
Operational State          Not applicable
Current HW State           Not applicable
LLDP Negotiated POE Power  (not available)
Version history
Revision #:
1 of 1
Last update:
‎04-07-2015 01:49 PM
Updated by:
Labels (1)
Contributors
