Environment- Tested in 6.4.3.0
Answer- If we execute both these commands for a campus Ap you will be getting the following error message from the controller “This command is only applicable for Remote Access Points” show ap wired stats [ip-addr <ip-addr>] [ap-name <ap-name>] show ap wired stats [ap-name <ap-name>] [client-mac <client-mac>] There has been changes made to the CLI output from AOS 6.4.3.0 were we should be able to see the command output for Cap(campus Ap’s) as well Here is the outputs tested in 6.4.3.0(Aruba7240) #show ap active Active AP Table---------------Name Group IP Address 11g Clients 11g Ch/EIRP/MaxEIRP 11a Clients 11a Ch/EIRP/MaxEIRP AP Type Flags Uptime Outer IP---- ----- ---------- ----------- ------------------- ----------- ------------------- ------- ----- ------ --------18:64:72:c9:97:6c default 172.16.0.253 0 AP:HT:1/15/18 0 225 Ea 13m:13s N/AWired User connected ================ (Aruba7240) #show userUsers----- IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roaming Essid/Bssid/Phy Profile Forward mode Type Host Name---------- ------------ ------ ---- ---------- ---- -------- ------- ------- --------------- ------- ------------ ---- ---------172.16.0.1 f0:1f:af:64:d6:c3 logon 00:00:00 18:64:72:c9:97:6c Wired 172.16.0.253:0/1 default tunnelUser Entries: 1/1 Curr/Cum Alloc:1/1 Free:0/0 Dyn:1 AllocErr:0 FreeErr:0 (Aruba7240) # show ap wired stats ap-name 18:64:72:c9:97:6c RAP Wired User Statistics-------------------------Mac Slot Port VLAN TX Pkts RX Pkts TX Bytes RX Bytes TX BCast Pkts TX BCast Bytes TX MCast Pkts TX MCast Bytes--- ---- ---- ---- ------- ------- -------- -------- ------------- -------------- ------------- --------------f0:1f:af:64:d6:c3 0 1 1 16 10 6435 1829 1 242 0 0 (Aruba7240) # show ap wired stats ap-name 18:64:72:c9:97:6c client-mac f0:1f:af:64:d6:c3 AP Wired User Statistics------------------------Counter Value------- -----Slot 0Port 1VLAN 1TX Packets 42TX Bytes 8439RX Packets 13RX Bytes 2581TX Broadcast Packets 13TX Broadcast Bytes 1428TX Multicast Packets 6TX Multicast Bytes 300
