Does the Gig port on M3 support 100Mbps speed?
Product and Software: This article applies to all Aruba controllers and ArubaOS versions.
The Gig ports on M3 support only 1Gbps speed and does not support 100Mbps speed.
Version history
Revision #:
1 of 1
Last update:
‎07-06-2014 10:02 PM
Updated by:
Labels (1)
