HOW TO DISABLE CLIENT MATCH FOR A SPECIFIC CLIENT.
Environment  :  All Aruba Os After 6.3
Use the following command to disable the client match for the client
#add ap arm client-match unsupported 3c:97:0e:4f:b3:86
Use this command to checkthe client is  listed  under  Client Match Unsteerable Clients list
 #show ap arm client-match unsupported
MAC                Unsteerable Flags    Last Steer Time       Total steers/successful
3c:97:0e:4f:b3:86  Administrator added  Mar 27 02:49:19 2014  0/0
S: Sticky L: Load Balance B: Bandsteer I: IOS
Total Unsteerable Clients:1
Use the following command to remove from the unsteerable clients list
#clear ap arm client-match unsupported client-mac 3c:97:0e:4f:b3:86
Version history
Revision #:
1 of 1
Last update:
‎07-03-2014 02:05 PM
Updated by:
Labels (1)
Contributors
Comments
Tim Haynie
I notice that this command is entered from EXEC mode. Thus, I have three questions:
  • Will this command persist after issuing "wr mem" and "reload"?
  • Will this command propogate to the other controllers in a master/local (or master/redundant master) environment?
  • Will the administratively added clients timeout from the unsupported list after the Client Match Unsteerable Client Ageout Interval (2 days by default)?
Thanks...
I also think the answers to Tim's questions would be a valuable addition to this article.
- No
- Locals, no. Redundant master, yes.
- No, they are permanent (no timer).
Has this behavior changed in 6.5.(1) ?  I've used it in 6.4, but it doesn't seem to be working now in 6.5.1.
(aruba7240-14) #add ap arm client-match unsupported 24:F0:94:A6:A2:19 reason administrative
Successfully adding unsupported client:24:f0:94:a6:a2:19
(aruba7240-14) #show ap arm client-match unsupported | include 24:F0:94:A6:A2:19
(aruba7240-14) #
