HOW-TO-DO-DATAPATH-PACKET-CAPTURE-FOR-WIRELESS-CLIENT-FROM-CONTROLLER.
Environment  :  All Aruba OS after 6.3
HOW TO DO DATAPATH  PACKET CAPTURE FOR WIRELESS CLIENT FROM CONTROLLER.
Use the following command to enable the Packet capture
(Aruba) #packet-capture datapath wifi-client <mac-address> ?
all                     Capture both decrypted and encrypted packets
decrypted               Capture decrypted packets only
encrypted               Capture encrypted packets only
 We Need to set a Destination for this capture(You can use either of these options)
(Aruba) #packet-capture destination ?
interface               Send captured packets to an interface
ip-address              Send captured packets to a remote destination
local-filesystem        Store captured packets on the controller in pcap files
(Aruba) #packet-capture destination interface ?
<slot/port>             Interface in <slot>/<port> format
(Aruba) #packet-capture destination ip-address ?
<ipaddr>                A.B.C.D  IP address
(Aruba) #packet-capture destination local-filesystem ?
<cr>
Note:If we use Local file system Capture  will be saved in the logs.tar of the controller .
You can also use the following command to Copy the packet capture to the flash
#packet-capture copy-to-flash datapath-pcap
Note: You can tftp/ftp the file out from the flash
Version history
Revision #:
1 of 1
Last update:
‎07-03-2014 02:06 PM
Updated by:
Labels (1)
Contributors
Comments
A heplful document but how do I configure the remote computer to receive the pcap?
You have to take care of the following after configuring the controller as shown above.
1. The Controller should be reachable to the destination IP
2. You should run packet capture ( Wireshark) on the destination
3. As the client traffic hitting the controller over GRE filter the packet capture with GRE
For your ref :
edit: sorry, probably wrong place to ask. Disregard.
