Hardware Models Not Supported from ArubaOS 6.5.0.0 and above
MVP
MVP
Q:
What are the hardware models that are not supported from Aruba OS 6.5.0.0 and above?
A:
Below is the list of hardware models that are not supported from Aruba OS 6.5.0.0 and above:
Version history
Revision #:
2 of 2
Last update:
‎03-24-2017 06:39 AM
Updated by:
Labels (1)
Contributors
