Ho to see admin users logged into the controller and how to delete the sessions?
MVP
MVP
Aruba controller running Aruba 6.4 and above
In the setup, I have logged into the controller using 3 different methods with the same username:
a. Console                             (serial cable)
b. SSH                                    (IP address:  10.20.25.21)
c. Websession                      (IP address:  10.20.25.21)
We can see the administrative users logged into the controller using the command "#show loginsessions"
(master) #show loginsessions
Session Table
ID  User Name  User Role  Connection From  Idle Time  Session Time
1   admin      root       EIA-232          00:00:00   00:39:18
2   admin      root       10.20.25.21      00:00:20   00:00:21
3   admin      root       10.20.25.21      00:00:28   00:00:30
a. EIA-232 denotes serial  / console connection.
b. Serial / console session ID is always going to be 1.
b. We can see only the IP address for SSH and websession.
To clear the websession,  we can execute the command in the console window.
Below we clear session ID 2 which was for SSH session (denoted by telnet). After executing the command SSH window will close / logout.
(master) #clear loginsession 2
Telnet Session Killed By Console User
Below we clear session ID 3 which was for WebUI. After executing the command below, we will be logged out of the webUI OR will be get a login widow to authenticate again:
(master) #clear loginsession 3
WebUI session Killed By Console User.
If we try to execute the command on the SSH, we will see the error below:
Session Table
1   admin      root       EIA-232          00:01:56   00:41:14
2   admin      root       10.20.25.21      00:00:00   00:02:17
3   admin      root       10.20.25.21      00:00:29   00:02:26
Command can be executed only on the Console
We cannot delete the console session as the session ID for console is always 1 and it is not allowed in "#clear loginsession" command:
(master) #clear loginsession ?
<id>                    Session id 2-32
Version history
Revision #:
2 of 2
Last update:
‎05-18-2016 01:41 PM
Updated by:
Labels (1)
Contributors
