How can we improve Spectralink roaming performance on 802.11a?
Product and Software: This article applies to all ArubaOS versions. This article applies to US country code configuration only.
Currently for indoor channels, only channels 36, 40, 44, 48, 149, 153, 157, 161 and 165 are supported with AP-60/61/70 or 85. Other indoor channels, 52, 56, 60, 64 and 100-140 are supported only with newer APs including AP-12X series running latest OS versions. The VoIP engineer must adjust the phones to only scan for these channels if they connect to legacy APs.
Depending on the size of the deployment, the phones will experience delayed roaming performance if the phones are scanning all the available 802.11a indoor channels. To improve performance, deselect the channels that the APs are not advertising.
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 01:13 PM
Updated by:
Labels (1)
Contributors
