How do I check Access Point (AP) license usage?
Product and Software: This article applies to all Aruba controllers and ArubaOS 3.1 and later.
Use the following command to check the AP license usage.
Example:
(Lab) #show ap license-usage
Total AP Licenses : 6  AP Licenses Used : 1  MUX Licenses Used : 0  Unused AP Licenses : 5  Total RAP Licenses : 4  RAP Licenses Used : 0  Total Ortronics AP Licenses : 0  Ortronics AP Licenses Used : 0  Total Indoor Mesh AP Licenses : 4  Indoor Mesh AP Licenses Used : 3  Total Outdoor Mesh AP Licenses : 0  Outdoor Mesh AP Licenses Used : 0
Version history
Revision #:
1 of 1
Last update:
‎07-01-2014 04:28 PM
Updated by:
Labels (1)
Contributors
