How do I check all the capacity threshold values in controller?
Question: How do I check all the capacity threshold values in controller?
Environment: This article applies to Aruba Mobility Controllers running ArubaOS.
By default a pre-defined threshold values are set on the controller to avoid any further downtime due to over utilization of the hardware resources.
Following images shows how to see the threshold from CLI and Web Interface of the controller:
From CLI:
From GUI:
1. Login into the Web Interface
2. On Configuration tab, navigate to Management > Threshold
Version history
Revision #:
1 of 1
Last update:
‎06-30-2014 01:41 PM
Labels (1)
Contributors
