How do I check band steering clients in bridge or split-tunnel mode? Is band steering supported in bridge or split-tunnel mode?
Product and Software: This article applies to all controllers and APs and ArubaOS 3.4.1 and later.
Band steering was introduced in ArubaOS 3.3. However, band steering was only supported in virtual AP tunnel forward mode. In tunnel mode, you can use the following command to check which clients are 5 GHz capable:
#show ap band-steering-clients
5GHz Capable Clients:227
00:21:6a:2e:01:00
00:14:6c:43:7e:c0
00:1e:65:7b:a6:c0
Version history
Revision #:
1 of 1
Last update:
‎06-30-2014 05:18 PM
Updated by:
Labels (1)
Contributors
