Question: How do I check the coverage map for an AP in RF_Protect Mobile 6.6?
Product and Software: This article applies to RFprotect Mobile 6.6.
Before RFprotect 6.6, under the Locate tab you could put the AP where it physically is on the map so you could get a coverage map.
But in RFprotect 6.6, instead of the Locate tab you have to go to the Survey tab in Mobile (which is right next to Locate and looks very similar) where you can move APs around for survey purposes.
