How do I completely allow or disallow airgroup on selected vlan?
Question How do I completely allow or disallow airgroup on vlan?
Environment This article applies to Aruba Mobility Controllers running ArubaOS version 6.3.0.0 and higher.
Starting from ArubaOS 6.3, AirGroup is enabled by default and allowed on vlans configured on controller. Based on the network requirement, administrator would like to allow or disallow a airgroup service on a particular vlan.
For eg:  Airgroup can be blocked in a guest vlan, so that they cannot discover airgroup servers running in the internal employee vlans.
For example, inorder to disable airgroup on vlan 101, take the below command in config mode:
(Aruba) #configure terminal
Enter Configuration commands, one per line. End with CNTL/Z
(Aruba) (config) #airgroup vlan 101 disallow
(Aruba) (config) #exit
In order to verify if airgroup is disabled on a vlan, execute the below show command:
(Aruba) #show airgroup vlan
Following images from a controller CLI shows how to configure and verify:
Version history
Revision #:
2 of 2
Last update:
‎07-11-2014 05:06 PM
Labels (1)
Contributors
