How do I configure wired captive portal?
Question:  How do I configure wired captive portal?
Product and Software: This article applies to all Aruba controllers and ArubaOS versions.
The configuration for captive portal for a physical (wired) port of the controller is same as the wireless configuration. Map a captive portal profile assigned to the initial role of the wired aaa profile.
The port should be marked as untrusted.
From the CLI:
#conf t
#interface fastethernet slot/port no trusted
Define a wired access AAA profile on the Advanced Services tab:
From the WebUI:
Advanced Services > Wired Access > from the drop-down menu, select the aaa profile that has the initial role mapped with captive portal profile.
Version history
Revision #:
1 of 1
Last update:
‎07-07-2014 01:58 PM
Labels (1)
Contributors
