How do I console into AP-124/AP-125?
Product and Software: This article applies to AP-12x and all ArubaOS versions.
The AP-12x has a console port just beneath the AP and you can use the normal console cable with a DB-9 connected to access it.
Version history
Revision #:
1 of 1
Last update:
‎07-01-2014 01:43 PM
Updated by:
Labels (1)
Contributors
