How do I determine if APs are down or up?
Product and Software: This article applies to all Aruba APs and ArubaOS 2.x and later.
Issue the following command, depending on the software version being used:
ArubaOS 2.5.x.x:
(master-2.5) #show sapm ap-search status ?
down APs that are down
up APs that are up
ArubaOS 3.1.0.x:
(Aruba800-3.1-MASTER) #show ap database status ?
down Show only APs that are down
up Show only APs that are up
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 07:30 AM
Updated by:
Labels (1)
