Controller Based WLANs
last person joined: one year ago
APs, Controllers, VIA
How do I get a single SNMP trap per AP up/down, instead of multiple alerts?
Jun 30, 2014 10:51 PM
Product and Software: This article applies to ArubaOS 3.1 and later.
The two kinds of alerts for an AP up/down event are:
  • AP up/down trap
  • BSSID up/down trap
You can avoid false alarms and reduce the volume of trap messages by disabling the BSSID up/down traps (wlsxBSSIDIsUp/wlsxBSSIDIsDown, 1109/1110) and using the AP up/down traps instead (wlsxNAccessPointIsUp/wlsxNAccessPointIsDown, 1040/1041).
(ArubaOS 3.x is required for specific trap configuration.)
The following are the steps to disable wlsxBSSIDIsUp & wlsxBSSIDIsDown traps in the Controller CLI:
  • configure terminal
  • snmp-server trap disable wlsxBSSIDIsDown
  • snmp-server trap disable wlsxBSSIDIsUP
  • end
  • write memory
When AP up/down traps are used, a down trap is posted about 2 minutes after the AP goes down (and heartbeat/keepalive counts are exhausted), and an up trap immediately the AP has registered.
Here is an excerpt from an AP Down trap packet, with Switch IP, Trap Number, and AP wired-MAC higlighted:
            enterprise: 1.3.6.1.4.1.14823.1.1.4
            (SNMPv2-SMI::enterprises.14823.1.1.4)
            agent-addr: internet (0)
                internet: 129.10.6.231 (192.168.6.231)
            generic-trap: enterpriseSpecific (6)
            specific-trap: 1041
            time-stamp: 495749100
            variable-bindings: 2 items
                Item
                    (SNMPv2-SMI::enterprises.14823.2.3.1.11.1.1.60)
                    valueType: value (0)
                        value: simple (4294967295)
                            simple: string-value (1)
                                Value: Hex-STRING: 07 D8 02 0F 0F 08 12 00 2D 05 00
                Item
                    (SNMPv2-SMI::enterprises.14823.2.3.1.11.1.1.1.0)
                                Value: Hex-STRING: 00 0B 86 C0 9A 1C
The minor disadvantage is that the AP is only identified by its wired MAC in this trap.
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Related Entries and Links
No Related Resource entered.
