How do I get the station RSSI values using SNMP?
Product and Software: This article applies to all Aruba controllers and ArubaOS 2.5 and later.
The station Received Signal Strength Indicator (RSSI) values are stored in the database. As such, if you have master and local redundancy configured, you need to query only the master controller to get the station RSSI values.
The OID for monStaInfoRSSI is .1.3.6.1.4.1.14823.2.2.1.6.7.2.1.1.5 .
Version history
Revision #:
1 of 1
Last update:
‎07-01-2014 04:45 PM
Updated by:
Labels (1)
Contributors
