How do I hard reset the ECS appliance?
Product and Software: This article applies to all Aruba ECS appliances.
On the front of the ECS appliance, a cover displays all the LEDs and has "Endpoint Compliance System" written on it.
Remove that front cover, and on the right side you will see the reset button just behind the LEDs.
Press the reset button and it will reset the ECS to the factory default settings.
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 09:58 AM
Updated by:
Labels (1)
Contributors
