How do I log XML queries and responses on an Aruba controller?
Question:  How do I log XML queries and responses on an Aruba controller?
Product and Software: This article applies to all Aruba controllers and ArubaOS versions.
When an external captive portal server is used, and if XML is used for the transaction, then the following commands are used to log the XML queries and responses.
First, enable debugging logging for the security process authmgr and security logging with warning level:
# logging level debugging security process authmgr
# logging level warning security
Then, view the output:
#show log security all
Example
(Aruba800) (config)# logging level debugging security process authmgr
(Aruba800) (config)# logging level warning security
(Aruba800) #show logging level verbose
LOGGING LEVELS
Facility Level Sub Category Process
network warnings N/A N/A
security warnings N/A N/A
security debugging N/A esi
security debugging N/A authmgr
system warnings N/A N/A
system debugging N/A esi
system informational all esi
user warnings N/A N/A
wireless warnings N/A N/A
(Aruba800) #show log security 15
Sep 22 16:09:29 :124030: <INFO> |authmgr| Received XML API cmd=user_delete, agent=172.16.0.253 IP=172.16.0.252
Sep 22 16:09:29 :124004: <DBUG> |authmgr| IP=172.16.0.252, MAC=00:01:02:03:04:05, name=''
Sep 22 16:09:29 :124004: <DBUG> |authmgr| role='logon', tout=0, vers='1.0'
Sep 22 16:09:29 :124004: <DBUG> |authmgr| auth='cleartext', key(5)='aruba'
Sep 22 16:09:29 :124004: <DBUG> |authmgr| Tx message to Sibyte. Opcode = 17, msglen = 134
Sep 22 16:09:29 :124032: <WARN> |authmgr| XML command=user_delete (3) result='Ok', error=''
Sep 22 16:10:16 :124004: <DBUG> |authmgr| RX (sock) message of type 50, len 1084
Sep 22 16:10:16 :124030: <INFO> |authmgr| Received XML API cmd=user_add, agent=172.16.0.253 IP=172.16.0.252
Sep 22 16:10:16 :124004: <DBUG> |authmgr| IP=172.16.0.252, MAC=00:01:02:03:04:05, name=''
Sep 22 16:10:16 :124004: <DBUG> |authmgr| role='logon', tout=0, vers='1.0'
Sep 22 16:10:16 :124004: <DBUG> |authmgr| auth='cleartext', key(5)='aruba'
Sep 22 16:10:16 :124004: <DBUG> |authmgr| Tx message to Sibyte. Opcode = 17, msglen = 134
Sep 22 16:10:16 :124032: <WARN> |authmgr| XML command=user_add (2) result='Ok', error=''
Sep 22 16:14:40 :124004: <DBUG> |authmgr| Rx message 14001/5221, length 153 from 127.0.0.1:8220
Sep 22 16:15:46 :124004: <DBUG> |authmgr| Tx message to Sibyte. Opcode = 17, msglen = 134
Version history
Revision #:
1 of 1
Last update:
‎07-07-2014 03:11 PM
Labels (1)
Contributors
