How do I monitor bandwidth usage on an Aruba AP mesh link?
Product and Software: This article applies to all Aruba controllers and ArubaOS 5.x and later.
If you want to understand the bandwidth load on a specific mesh link, you must get information about it.
To get information about the bandwidth load on a specific mesh link, follow these steps in the ArubaOS WebUI:
1) Navigate to Monitoring > Access Points.
2) Select the mesh point that you want to monitor.
3) Click Overview.
4) Change the refresh rate to 5 seconds.
1351 image 1
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 06:23 PM
Updated by:
Labels (1)
Contributors
