How do I mount a network storage device on the controller?
Question:  How do I mount a network storage device on the controller?
Product and Software: This article applies to Aruba 650 Controllers and ArubaOS 3.4.x and later.
When you first plug in a storage device, it comes up as an unmounted device.
(host)(config) #show usb-storage
USB Disk Table
Device Name Device Alias Num of Partitions Size Mounted partitions
Maxtor-Basics_Desktop-2HBADMJ4 Maxtor1TB 1 1000GB No
WD-2500BEV_External-WD-WXE508ET3777 WD25OGB 1 250 GB No
(host)
To enable NAS service, which mounts the device, issue the following command:
(host)(config)#service network-storage
Version history
Revision #:
1 of 1
Last update:
‎07-07-2014 02:31 PM
Labels (1)
Contributors
Tags (1)
