How do I prevent MUX tunnel forwarding loops?
Product and Software: This article applies to all Aruba controllers running ArubaOS 3.3.2 and later.
ArubaOS 3.3.2 has added the new command "mux-loop-prevention" to prevent MUX tunnel forwarding loops. When it is enabled, the STM process sets the NOTUNLOOPS tunnel flag in each MUX tunnel to instruct the datapath not to flood a frame from a tunnel to any MUX tunnel. This command is used to reduce flooding and eliminate forwarding loops that involve tunnels.
(config) #mux-loop-prevention
Version history
Revision #:
1 of 1
Last update:
‎07-01-2014 03:00 PM
Updated by:
Labels (1)
