How do I run an RF test with the built-in Aruba RFT utility?
Product and Software: This article applies to ArubaOS 3.x and later.
Aruba has a built-in RF testing tool with basic functionalities. The following tests are available.
Antenna Connectivity
This command checks AP antenna connectivity. The Signal to Noise Ratio (SNR) of all the antennae on the AP is tested.
#rft test profile antenna-connectivity ap-name <Name of the AP> dest-mac <mac address of client> phy <a or g> | radio <0 or 1>
Link Quality
This command determines the most suitable data rate for a given target. It checks the success rate in all the data rates possible by the AP.
#rft test profile link-quality ap-name <Name of the AP> dest-mac <mac address of client> phy <a or g> | radio <0 or 1>
Raw
This command sends a null data to the wireless client and tests the success rate. It can be considered as an 802.11 ping.
#rft test profile raw ap-name <Name of the AP> dest-mac <mac address of client> phy <a or g> | radio <0 or 1>
Examples
(slc-aescwlanlc01) #rft test profile antenna-connectivity ap-name slc-aesc-2ap3 dest-mac 00:1F:3B:C8:C4:C9 phy g
Transaction ID: 7601
(slc-aescwlanlc01) #show rft result trans-id 7601
Profile AntennaConnectivity, TransID 7601, AP 148.172.53.6, Dest 00:1f:3b:c8:c4:c9, Radio 1
Antenna Connectivity Test Result
Antenna 1: Avg S/N ratio: 35 Success Rate: 93%
Antenna 2: Avg S/N ratio: 35 Success Rate: 92%
Difference: 0 1%
Destination went into power-save during the test. Results may not be accurate.
For accurate results, disable power-save on the destination.
(slc-aescwlanlc01) #rft test profile link-quality ap-name slc-aesc-2ap3 dest-mac 00:1F:3B:C8:C4:C9 phy g
Transaction ID: 6401
(slc-aescwlanlc01) #show rft result trans-id 6401
Profile LinkQuality, TransID 6401, AP 148.172.53.6, Dest 00:1f:3b:c8:c4:c9, Radio 1, Num Packets 100
Data Rate Success Rate
1.0 Mbps 88%
2.0 Mbps 93%
5.5 Mbps 86%
6.0 Mbps 95%
9.0 Mbps 91%
11.0 Mbps 96%
12.0 Mbps 97%
18.0 Mbps 93%
24.0 Mbps 78%
36.0 Mbps 97%
48.0 Mbps 98%
54.0 Mbps 96%
(slc-aescwlanlc01) #rft test profile raw ap-name slc-aesc-2ap3 dest-mac 00:1F:3B:C8:C4:C9 phy g
Transaction ID: 6301
(slc-aescwlanlc01) #show rft result trans-id 6301
Profile RAW, TransID 6301, AP 148.172.53.6, Dest 00:1f:3b:c8:c4:c9, Radio 1
Measurement Value
Total Packets 100
Tx Success 85
Tx Failure 15
Excessive Retries 15
Total Retries 54
Avg S/N ratio 35
Tx by Antenna 1 70
Tx by Antenna 2 30
Version history
Revision #:
1 of 1
Last update:
‎06-30-2014 05:04 PM
Updated by:
Labels (1)
Contributors
