How do I set the LED operation mode for AP-10x, AP-12x, and RAP-5x?
Question: How do I set the LED operation mode for AP-10x, AP-12x, and RAP-5x?
Product and Software: This article applies to all Aruba controllers running ArubaOS 5.0 and later and applies to AP-10x, AP-12x, and RAP-5x.
The LED operation mode for AP-10x/AP-12x/RAP-5x/AP-9x is a configurable parameter in the system profile of AP-Group. Use the following commands to set the the LED operation mode.
(config) #ap system-profile default
(AP system profile "default") #led-mode ?
normal Normal mode
off All LEDs off
(AP system profile "default") #exit
#ap-leds ap-name ?
<ap-name> Control LEDs on AP with this name
#ap-leds ap-name asd ?
blink Make LEDs blink for identification
normal Restore LEDs to their normal behavior
#show ap system-profile default
Parameter Value
LMS IP N/A
Backup LMS IP N/A
LMS Preemption Disabled
LMS Hold-down Period 600 sec
Number of IPSEC retries 360
LED operating mode (AP-10x/AP-12x/RAP-5x only) normal
Version history
Revision #:
1 of 1
Last update:
‎07-07-2014 04:20 PM
Labels (1)
Contributors
