How do I understand an Aruba antenna's specifications/properties looking at the antenna name? How does Aruba antenna naming convention works?
Environment : This article applies only to the antennas sold by Aruba Networks and not any third party antennas.
A typical Aruba antenna is named in the following format:
ANT – P x Q – ABCC
P – number of transmit antennas
Q – number of receive antennas
For eg, “2x2" represents 2 transmit and 2 receive MIMO antennas.
A --
If it is a dual band antenna, it is represented by "D".
If it is a 2.4 GHz single band antenna, it is represented by "2".
If it is a 5 Ghz single band antenna, it is represented by "5".
B --
0 = omnidirectional
1 = 10 degrees or less
2 = 20 degrees
3 = 30 degrees
4 = down-tilt omnidirectional
5 = {reserved}
6 = 60 degrees
7 = 70 degrees
8 = 120 degrees
9 = 90 degrees
CC - This is a two digit number that represents the antenna gain in dBi
For example,
"ANT-2x2-5010" is a 2x2 MIMO 5 GHz, Omnidirectional antenna with a gain of 10 dBi.
"ANT-2x2-2714" is a 2x2 MIMO 2.4 GHz, 70 Degree antenna with a gain 14 dBi,
To get the latest list of Aruba's antenna products, please visit http://www.arubanetworks.com/products/access-points/indoor-and-outdoor-antennas/.
Version history
Revision #:
1 of 1
Last update:
‎06-28-2014 07:43 AM
Updated by:
Labels (1)
Contributors
