Product and Software: This article applies to Aruba AP-80MB/SB.
Aruba Networks AP-80SB#show version
Version v1.1.7.6B04
Aruba Networks AP-80SB#copy tftp file
1. Application image
2. Config file
3. Boot block image
Select the type of download<1,2,3>: [1]:
TFTP Source file name:zz-img-ap80_1_1_6_5.bin
TFTP Server IP:192.168.1.2
Firmware version of system is v1.1.7.6B04 and Updating Run-Time code v00.00.01 N
OW!
This firmware is compatible with hardware.
Warning! Updating firmware may cause configuration settings to be incompatible.
(Suggestion:Using new default configuration settings lets system be more
efficient,but system will lose current settings.)
Do you want to use NEW CONFIG SETTINGS? <y/n> [n]:
