How do I upgrade the sensor firmware?
Product and Software: This article applies to RFprotect sensor (network chemistry) and all RFprotect versions.
You can upgrade the sensor firmware either through the sensor properties or through the sensor template.
Upgrading Through the Sensor Properties
Navigate to Configuration > Sensors, right-click the sensor, navigate to Sensor Properties > Control > Firmware, select the location of the firmware, and click OK.
Upgrading Through the Sensor Template
Right-click the sensors, Navigate to Configuration > Sensor Templates > Add Template > Enter template name > Firmware, and specify the location of the firmware and click OK. Navigate toConfiguration > Sensors windows, and double-click the sensor. Click the General tab, select the template you just created from the drop-down menu in the parameter 'template', and click OK.
Note: It will take 10-15 minutes to upgrade the sensor.
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 07:29 AM
Updated by:
Labels (1)
Contributors
