How do bandwidth contracts work?
Product and Software: This article applies to all Aruba controllers and ArubaOS versions.
To find out whether a bandwidth contract will be applied to a particular role, issue the 'show rights' command:
(arub) #show rights
RoleTable
Name          ACL Bandwidth                 ACL List  Type
ap-role         4 Up: No Limit,Dn: No Limit           System
cpbase         12 Up: No Limit,Dn: No Limit cpbase    System
denyall        10 Up: No Limit,Dn: No Limit denyall   System
guest           3 Up: No Limit,Dn: No Limit           System
guest-logon     7 Up: No Limit,Dn: No Limit           System
logon           1 Up: No Limit,Dn: No Limit           System
stateful-dot1x  5 Up: No Limit,Dn: No Limit           System
trusted-ap      6 Up: No Limit,Dn: No Limit           System
To find out whether a bandwidth contract is being applied to a specific user, issue the 'show user' command:
(Aruba800) #show user ip 10.100.119.92
Name: localuser, IP: 10.100.119.92, MAC: 00:30:65:28:3f:a7, Role:authenticated, ACL:17, Age: 00:00:01
Authentication: Yes, status: successful, method: 802.1x, protocol: EAP-TTLS, server: apang
Bandwidth contract = 20m (20000000 bits/sec)
Role Derivation: default for authentication type 802.1x
Idle timeouts: 0, ICMP requests sent: 0, replies received: 0
Mobility state - Home Agent: Yes, Proxy ARP: No, Tunnel ID: 0
Flags: internal=0, trusted_ap=0, delete=0, roaming=0
Flags: innerip=0, outerip=0, guest=0, station=0, download=1
Auth fails: 0, phy_type: 2, reauth: 0, Bwm Contract: 1
Vlan default: 1, Assigned: 0, Current: 0
Mobility Messages: L2=0, Move=0, Inter=0, Intra=0, ProxyArp=0, Flags=0x0
Tunnel=0, SlotPort=0x1021, Port=4169
Role assigned: n/a, VPN: n/a, Dot1x: n/a
To find out the statistics for a particular contract, first find out what contracts have been configured by issuing the 'show aaa bandwidth-contracts' command:
(Aruba800) #show aaa bandwidth-contracts
Contract Id  Rate (bits/second)
20m       1  20000000
Total contracts = 1 (user configured = 1)
Then to find out the statistics on that particular contract ID, issue the 'show datapath bwm table' command:
(aruba) #show datapath bwm table
Datapath Bandwidth Management Table Entries
CPU  Contract Bits/sec   Policed    Avail Bytes Queued Bytes/Pkts
0    1        200000000      0       781136           0/0
0    2        200000000 565327        78125           0/0
0    3        20000000       0        78125           0/0
0    4        10000128       0        39063           0/0
0    5        500000000      0      1953125           0/0
0    6        5000192        0        19532           0/0
When the controller is under stress, use the 'show datapath bwm table' command to check the type of traffic that is consuming a lot of CPU. If the Policed and Queued Bytes/Pkts columns have non-zero values and they continue to increment, the network may have a lot of that specific type of traffic. This information helps to narrow down the problem.
#show datapath bwm
0    1       20000000   0           78125         0/0
0    2        4000000   0           15625         0/0
0    3      160000000   0          625000         0/0
0    4        4000000   0           15625         0/0
0    5        2000128   0            7813         0/0
0    6        2000128   0            7813         0/0
0    7        2000128   0            7813         0/0
1    1        5000192   0           19532         0/0
1    2         256000   0            1000         0/0
Bandwidth contract 1 to contract 7 for CPU 0 are built in to the system:
  • Contract 1: untrusted unicast
  • Contract 2: untrusted multicast
  • Contract 3: trusted unicast
  • Contract 4: trusted multicast, that is, BPDU packets
  • Contract 5: frames that need to be routed
  • Contract 6: session mirror packets
  • Contract 7: user miss frames
Bandwidth contracts for CPU 1 are the user-defined bandwidth contracts.
The best practice is to apply bandwidth contracts to user VLANs to reduce the amount of broadcast and multicast traffic. This contract also drops good broadcast traffic. When the same contract is applied to multiple VLANs, the resources are shared by a single buffer. A separate contract should be used when the resources are low. Review the following example.
"test1" has a contract ID of 3 and it only has 100 bytes of buffer free. The buffer could also go to zero. Assign some user VLANs to a new bandwidth contract. In the following example, "test2" is the new contract.
Sample Output
(SanLeandro2400) #show aaa bandwidth-contracts
Bandwidth Contracts
test     1   100000000
test1    3   256000       <<<< "test1" with ID of 3
test2    2   256000
Total contracts = 3
Per-user contract total = 4096
Per-user contract usage = 0
(SanLeandro2400) #
(SanLeandro2400) #
(SanLeandro2400) #show datapath bwm table
0      1     10000000         0     312500          0/0
0      2      2000000         0      62500          0/0
0      3     80000000         0    2499886          0/0
0      4      2000000    687313      61798          0/0
0      5      1000000         0      31250          0/0
0      6      1000000         0      31250          0/0
0      7      1000000         0      31250          0/0
1      1    100000000         0    3125000          0/0
1      2       256000         0       8000          0/0
1      3       256000  12384848        100          0/0 <<< Contract ID #3
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 04:38 PM
Updated by:
Labels (1)
Contributors
Comments
Is bandwidth contact applied to a user mac-address on the user-table? or to the IP-address of a user in the user-table?
we have a scenario, where a wifi device has to own two IP-address from the same subnet. How does a bandwidh contact apply(when the bandwidth contact is applied on per user basis)?
