How does client match handle unsteerable clients?
Applicable for 6.2 and above ArubaOS which features ARM 3.0
Client Match – Handling unsteerable clients
Controller keeps track of successive steer failures for the respective steer reason
to the desired destination radio
Upon 5 consecutive failed steer attempts, controller notifies the associated AP
to mark the client as unsteerable (with reason)
AP will not attempt to steer that client for that specific reason (e.g. if a client is deemed
non band steerable, the AP can still continue to do a sticky health check rather than
completely overlooking the client)
Controller logs the client in a unsteerable list that can be read using
“show ap arm client-match unsupported”
Default Unsteerable client ageout 2880 mins
Example:
(Aruba3600) #show log arm 50 | include 18:46:17:eb:ab:40
Jan 3 14:37:53 :700101:  <DBUG> |stm| |client-mgmt| Tracking unsuccessful failure for client 18:46:17:eb:ab:40 num fails 2
Jan 3 14:38:21 :700101:  <DBUG> |stm| |client-mgmt| Tracking unsuccessful failure for client 18:46:17:eb:ab:40 num fails 3
Jan 3 14:38:31 :700101:  <DBUG> |stm| |client-mgmt| AP d8:c7:c8:80:08:40 Adding new vbr_nbr d8:c7:c8:80:08:40 for client 18:46:17:eb:ab:40
Jan 3 14:38:31 :700101:  <DBUG> |stm| |client-mgmt| AP d8:c7:c8:80:08:40 Adding new vbr_nbr d8:c7:c8:80:08:50 for client 18:46:17:eb:ab:40
Jan 3 14:38:33 :700101:  <DBUG> |stm| |client-mgmt| Client Match: Unsteerable STA 18:46:17:eb:ab:40 consec_fails 3, giving up
Jan 3 14:39:04 :702001:  <DBUG> |AP ap135@10.3.136.245 sapd| |client-mgmt| Unsteerable client 18:46:17:eb:ab:40 Reason: Band steer
Jan 3 14:39:07 :702001:  <DBUG> |AP ap135@10.3.136.245 sapd| |client-mgmt| Unsteerable client 18:46:17:eb:ab:40 Reason: Band steer
Version history
Revision #:
1 of 1
Last update:
‎06-26-2014 03:00 PM
Updated by:
Contributors
