How does connection-type defined in Clustering AOS 8.0?
MVP
MVP
Q:
A:
Below are the connection types for the controllers which is a part of clustering in AOS 8.0.
1. L2-connected.
2. L3-connected.
If all the Vlans are shared across all the controllers in the cluster then it will be defined as L2-connected.
If all the Vlans are NOT shared across all the controllers in the cluster then it will be defined as L3-connected.
Example:
In the below case, vlan 2160 is NOT shared across the vlan hence the connection-type is defined as L3-connected.
In order to have hitless failover, the controllers in the cluster should be L2-connected. It's always recommended to share all the user vlan across the controllers in the cluster.
Version history
Revision #:
2 of 2
Last update:
‎03-26-2017 01:16 AM
Updated by:
Labels (1)
Contributors
