How does the aruba controller decide on BAND color code under voice call-quality outputs?
Environment  :  This article applies to Aruba Mobility Controllers.
For the ease of monitoring voice quality, Aruba Controller categorize voice calls with BAND, with values such as (Green/Yellow/Red)
Below shown is screenshot for "show voice call-quality":
Here is controller comes to a conclusion of BAND color code:
R-Value >= 80 :   Green
R-Value >= 60 and <80 :  Yellow
R-Value >= 0 and < 60 :  Red
R-value / R-factor:
The R-value is a measure of voice quality ranging from a best case of 100 to a worst case of 0. The parameters included in the computation of the R-Factor are fairly extensive, covering factors such as echo, background noise, signal loss, codec impairments and others. R-Factor is a technical version of the MOS score…whereas MOS score is subjective rating based what the end user hear. R-value uses technical data to come up with the number
Version history
Revision #:
1 of 1
Last update:
‎07-04-2014 11:01 AM
Updated by:
Labels (1)
Contributors
