How does the client match steer the 802.11v clients
Environment : Controller >> AP >> 802.11v clients associated to these Aps
Client Match will use 11v BSS transition management request to steer the 11v capable clients.
#show ap association
The phy column shows client's operational capabilities for current association
Flags: A: Active, B: Band Steerable, H: Hotspot(802.11u) client, K: 802.11K client, R: 802.11R client, W: WMM client, w: 802.11w client V: 802.11v BSS trans capable
PHY Details: HT   : High throughput;      20: 20MHz;  40: 40MHz
             VHT  : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
             <n>ss: <n> spatial streams
Association Table
Name          bssid              mac                auth  assoc  aid  l-int  essid       vlan-id  tunnel-id  phy              assoc. time      num assoc  Flags  Band steer moves (T/S)
ap225.office  18:64:72:d4:8d:d0  80:ea:96:d9:90:86  y     y      1    20     aruba-main  1        0x10009    a-HT-40sgi-1ss   1m:16s           5          WVKRAB  0/0
ap225.office  18:64:72:d4:8d:d1  24:a2:e1:35:32:81  y     y      3    20     aruba-psk   1        0x1002b    a-HT-40sgi-2ss   3h:24m:27s       1          WVAB   0/0
Num Clients:14
Total num of 5G capable clients:11
Total num of 5G capable clients in 2.4G band:6
Total num of 5G capable clients in 5G band:5
Total num of 2.4G only clients:3
Association Table
Num Clients:14
Version history
Revision #:
1 of 1
Last update:
‎04-08-2015 04:12 AM
Updated by:
Labels (1)
Contributors
