How does the fast-roaming feature work?
The fast-roaming feature is disabled by default, so Aruba OS does not allow a wifi client to associate to more than one AP at a time. When that happens, the old AP sends a deauth frame to the client.
When the fast-roaming feature is enabled, a wifi client is allowed to keep multiple associations with multiple APs at a time to help that client with reassociation and roaming from one AP to another.
Here is a snapshot of a packet trace in both cases:
With fast-roaming
Timestamp stype SA DA BSS signal Misc
Nov 29 17:13:26 reassoc-resp 00:0b:86:a0:bb:f0 00:09:5b:a1:24:9d 00:0b:86:a0:bb:f0 15 Success
Nov 29 17:13:26 reassoc-req 00:09:5b:a1:24:9d 00:0b:86:a0:bb:f0 00:0b:86:a0:bb:f0 0 -
Nov 29 17:13:26 auth 00:0b:86:a0:bb:f0 00:09:5b:a1:24:9d 00:0b:86:a0:bb:f0 15 Success
Nov 29 17:13:26 auth 00:09:5b:a1:24:9d 00:0b:86:a0:bb:f0 00:0b:86:a0:bb:f0 0 Success
Nov 29 17:12:42 reassoc-resp 00:0b:86:a0:a5:80 00:09:5b:a1:24:9d 00:0b:86:a0:a5:80 15 Success
Nov 29 17:12:42 reassoc-req 00:09:5b:a1:24:9d 00:0b:86:a0:a5:80 00:0b:86:a0:a5:80 0 -
Nov 29 17:12:42 auth 00:0b:86:a0:a5:80 00:09:5b:a1:24:9d 00:0b:86:a0:a5:80 15 Success
Nov 29 17:12:42 auth 00:09:5b:a1:24:9d 00:0b:86:a0:a5:80 00:0b:86:a0:a5:80 0 Success
Nov 29 17:11:36 assoc-resp 00:0b:86:a0:bb:f0 00:09:5b:a1:24:9d 00:0b:86:a0:bb:f0 15 Success
Nov 29 17:11:36 assoc-req 00:09:5b:a1:24:9d 00:0b:86:a0:bb:f0 00:0b:86:a0:bb:f0 0 -
Nov 29 17:11:36 auth 00:0b:86:a0:bb:f0 00:09:5b:a1:24:9d 00:0b:86:a0:bb:f0 15 Success
Nov 29 17:11:36 auth 00:09:5b:a1:24:9d 00:0b:86:a0:bb:f0 00:0b:86:a0:bb:f0 0 Success
Without fast-roaming
Nov 29 17:18:49 reassoc-resp 00:0b:86:a0:a5:80 00:09:5b:a1:24:9d 00:0b:86:a0:a5:80 15 Success
Nov 29 17:18:49 deauth 00:0b:86:a0:bb:f0 00:09:5b:a1:24:9d 00:0b:86:a0:bb:f0 15 -
 <----- The former AP sends a deauth to the client
Nov 29 17:18:49 reassoc-req 00:09:5b:a1:24:9d 00:0b:86:a0:a5:80 00:0b:86:a0:a5:80 0 -
Nov 29 17:18:49 auth 00:0b:86:a0:a5:80 00:09:5b:a1:24:9d 00:0b:86:a0:a5:80 15 Success
Nov 29 17:18:49 auth 00:09:5b:a1:24:9d 00:0b:86:a0:a5:80 00:0b:86:a0:a5:80 0 Success
Nov 29 17:18:05 assoc-resp 00:0b:86:a0:bb:f0 00:09:5b:a1:24:9d 00:0b:86:a0:bb:f0 15 Success
Nov 29 17:18:05 deauth 00:0b:86:a0:a5:80 00:09:5b:a1:24:9d 00:0b:86:a0:a5:80 15 -
Nov 29 17:18:05 assoc-req 00:09:5b:a1:24:9d 00:0b:86:a0:bb:f0 00:0b:86:a0:bb:f0 0 -
Nov 29 17:18:05 auth 00:0b:86:a0:bb:f0 00:09:5b:a1:24:9d 00:0b:86:a0:bb:f0 15 Success
Nov 29 17:18:05 auth 00:09:5b:a1:24:9d 00:0b:86:a0:bb:f0 00:0b:86:a0:bb:f0 0 Success
To enable fast-roaming, use these commands:
Aruba OS 2.5:
(A2400) (config) #stm fast-roaming enable
(A2400) (config) #end
Aruba OS 3.x:
(A800) (config) #wlan virtual-ap default  (A800) (Virtual AP profile "default") #fast-roaming  (A800) (Virtual AP profile "default") #end
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 08:21 AM
Updated by:
Labels (1)
Contributors
