How frequently do dot1x clients need to re-authenticate?
By default, clients do not need to re-authenticate once connected. This knob is disabled by default on the controller. The knob can be enabled and configured to a specific time between 80-864000.  The configuration falls under "aaa authentication dot1x <profile>". Please see below:
(Aruba3600) (config) #show aaa authentication dot1x default | include Reauth
Reauthentication Interval                                  86400 sec
Use Server provided Reauthentication Interval              Disabled
Maximum Number of Reauthentication Attempts                3
Reauthentication                                           Disabled
Disable rekey and reauthentication for clients on call     Disabled
Version history
Revision #:
1 of 1
Last update:
‎06-26-2014 09:44 AM
Updated by:
