How long data is stored in MMS?
The MMS server collects stats from the controllers every 15 minutes. To limit the total storage capacity needed, older data is consolidated to lower density records (stats rollup) in the following way:
1. The last 96 entries of 15 min data is kept (one day worth); older entries will be consolidated into hourly data.
2. The last 168 entries of hourly data is kept (one week worth); older entries will be consolidated into daily data.
3. The last 31 entries of daily data is kept (one month worth); older entries will be consolidated into weekly data.
4. The last 52 entries of weekly data is kept (one year worth); older entries will be purged from database
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 07:58 AM
Updated by:
Labels (1)
Contributors
