How long the PMKID will be cached?
This article applies to all the versions of Aruba OS
The PMKID is cached for 8hrs by default. However this is configurable from the 802.1X Authentication Profile.
(Aruba) (config) #show aaa authentication dot1x default | include PMKSA
Time interval after which the PMKSA will be deleted        8 hr(s)
(Aruba) (config) #aaa authentication dot1x default
(Aruba) (802.1X Authentication Profile "default") #timer keycache-tmout ?
<kc-tmout>              Time interval in Hours. Range: 1-2000. Default: 8 hrs.
Version history
Revision #:
1 of 1
Last update:
‎06-26-2014 10:38 AM
Updated by:
Contributors
