How many USB devices can I connect to an Aruba 600 Series controller?
Product and software: This article applies to Aruba 600 Series controllers and ArubaOS 3.4.x.
Aruba 600 Series controllers have functional support for four USB devices. Internally, six USB devices are supported to accommodate secondary storage devices found on some printers.
Printers may have a slot for compact flash or SD memory cards. If the slot is empty, ArubaOS filters it out. If any of the slots contain a memory card, it is discovered and listed in the output. But this secondary storage media is not supported.
The 'show USB' command shows the connected USB devices:
(ARUBA) #show usb
USB Device Table
Address  Product  Vendor  ProdID  Serial           Type     Profile State
 3        USB DISK  090c   1000    AA08583000007946 Storage
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 05:57 AM
Updated by:
Labels (1)
Contributors
