How many concurrent VIA users can exist on an Aruba controller?
Product and Software: This article applies to ArubaOS 5.0 and later.
This table shows the number of VIA IPsec sessions that an Aruba controller can handle.
Controller
Concurrent
IPsec Tunnels
With SSL Fallback Enabled
620
256
128
650
512
256
651
512
256
3200
2048
1024
3400
4096
2048
3600
4096
2048
M3
4096
2048
Note: If SSL fallback is enabled, each user consumes two sessions so the IPsec numbers are halved.
Version history
Revision #:
1 of 1
Last update:
‎07-03-2014 11:14 AM
Updated by:
Labels (1)
Contributors
Tags (4)
