How much memory is allocated on 3000 series, M3 and 7200 series controllers for “Firewall Visibility” functionality?
Environment : This article applies to all the 3000 series, M3 and 7200 series controllers running AOS version 6.3.0.0 or higher.
Following table shows memory allocated for various controller platforms:
Platform Session supported Memory allocated
6xx              --- Not supported
3200/3400 32K 16MB
3600/M3 64K 32MB
7210 128K 64MB
7220 256K 128MB
7240 512K 256MB
In addition to this, there is some additional memory allocated to handle the overheads caused in continuously classifying the traffic.
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 02:16 PM
Updated by:
Labels (1)
Contributors
Tags (3)
