How on controller do I clear airgroup users and statistics for airgroup?
Question How on controller do I clear airgroup users and statistics for airgroup?
Environment This article applies to Aruba mobility controllers running ArubaOS version 6.3 or higher.
While troubleshooting Airgroup issues on controller, certain times it is necessary to clear the counters in order to understand the traffic patterns and other statistics. Below command would help us to clear the airgroup counters:
#Clear airgroup Statistics
#Clear airgroup user
Following image shows the description of each paramater under Clear command:
Version history
Revision #:
1 of 1
Last update:
‎07-11-2014 03:19 PM
Labels (1)
Contributors
