How to Block IPv6 traffic initiated from guest users ?
It is not possible for the network administrator to disable IPv6 on all the guest clients. So this may lead to unwanted IPv6 traffic on our network.
User-added image
Steps to block ipv6 traffic from guest users:
  • Create ACL to block IPv6 traffic.
ip access-list eth block-ipv6-acl
  deny 0x86dd
  permit any
  • Apply the same ACL to the guest user roles.
user-role Guest
  access-list eth block-ipv6-acl position 1
This can also be applied to uplink port if needed.
  • Apply the ACL to the physical uplink ports on the controller.
interface gigabitethernet 2/0
  ip access-group block-ipv6-acl in
Version history
Revision #:
1 of 1
Last update:
‎07-04-2014 12:44 AM
Updated by:
Labels (1)
Contributors
