The Mobility Controller should be minimum running AOS: 8.x or above.
From WebUI:
To Enable:
Step 1: Mobility Master-> Configuration-> System-> Licensing-> Usage-> Global License Pool->
Step 2: Check the "Feature Enabled" box for the respective licenses to enable it
Note: AP License, MM License and VMC licenses are enabled by default.
To Disable it:
Uncheck the "Feature Enabled" box for the respective licenses to disable it.
From CLI:
To Enable
Step 1: Get in to the MM directory. Step 2: From configuration mode, get in to the respective license pool and enable the respective licenses
(Aruba-MM) [mynode] (config) #cd /mm (Aruba-MM) [mm] (config) #license-pool-profile-root (Aruba-MM) ^[mm] (License root(/) pool profile) # acr-license-enable enable ACR feature no Delete Command pefng-licenses-enable enable PEFNG feature rfp-license-enable enable RFP feature webcc-license-enable enable WebCC feature xsc-license-enable enable XSEC feature (Aruba-MM) ^[mm] (License root(/) pool profile) #
To Disable
From configuration mode, get in to the respective license pool and use "no" command to disable the APs
(Aruba-MM) [mynode] (config) #cd /mm Maniraj-Aruba-MM) [mm] (config) #license-pool-profile-root (Aruba-MM) ^[mm] (License root(/) pool profile) # no acr-license-enable (Aruba-MM) ^[mm] (License root(/) pool profile) # no rfp-license-enable (Aruba-MM) ^[mm] (License root(/) pool profile) # no webcc-license-enable
To Check if the respective License is enabled or not, use the following command
(Aruba-MM) [mynode] #show license License Table ------------- Key Installed Expires(Grace period expiry) Flags Service Type --- --------- ---------------------------- ----- ------------ J6kL3BzQ-jLSyTL+/-ByJi+BPc-lvsEDKkd-kQV6VQ3r-XA/aZ5QT-YyOQH4Xz-I4ZcLHxp-e4DQ96Z9-5G8 2017-01-17 11:48:23[1] 2017-02-16 11:48:23 E Next Generation Policy Enforcement Firewall Module: 32 z0nFTS4c-rUkHnyRJ-qHpJtdPK-GXdL2UCL-UcyGGnuw-YxzkCJS3-jvbmSxL+-cbzSFZlj-MNAEvYz/-NEQ 2017-01-17 11:52:11[1] 2017-02-16 11:52:11 E Access Points: 32 WRMlRsMO-h3qbtQCg-bXUGQ06r-yy6l91EM-wlTG3upv-RvIkZTTD-eve4Zsxl-lHe8sZbE-GnOn775l-6/M 2017-01-17 11:53:10[1] 2017-02-16 11:53:10 E MM: 32 YnUvN6cV-XG4p+ssF-+tUU3/HZ-bUvIBMYe-16pT+F7r-15xwzZRg-NSK2GM1Q-P+DuYd/m-KerLxXDC-jWg 2017-01-17 11:53:28[1] 2017-02-16 11:53:28 E RF Protect: 32 DnFg4EUB-n0cvvgjI-AE8qt08E-k02qDrZs-lOW0Qqew-7vwavvVR-xvjMxigm-W6ntamAI-Gw5vGHCP-XcM 2017-01-17 11:54:57[1] 2017-02-16 11:54:57 E VMC: 32 jGgl+NLl-MVifMjVq-JMVpusWw-xL4O9seI-PPQUQ2Yv-HHDKLBV0-kkmarJTn-1yUE91Sa-eK+rZETx-Il8 2017-01-20 13:02:58[2] 2017-02-19 13:02:58 E WebCC: 32 License Entries: 6 Flags: A - auto-generated; E - enabled; S - Subscription; R - reboot/activation key required to activate; D - Not enabled on license client Note: Time under 'Installed' for Subscription licenses is the license generation time. (Aruba-MM) [mynode] #
The Flag "E" Indicates the license is Enabled.
