How to Transfer License from 6.x Controller to 8.x Controller on My Networking Portal?
MVP
MVP
The Mobility Controller should be minimum running AOS: 8.x or above to make use of the transferred license
  • If a controller holds licenses installed before Migration to 8.x it is no longer valid.
  • The existing license From 6.x controller needs to be transferred to 8.x VMM for the license to work.
Login in to the My networking Portal using the following URL
www.hpe.com/networking/support
Step 1:
Click on "My License" Tab and click on "Transfer License to new platform"
Step 2:
In the "Search" box enter the serial number of controller
Step 3:
From the output, select one of the licenses tied to the controller serial (it doesn’t matter which) and click the ‘>>’ icon on the right
Step 4:
When the license loads, click ‘Next’ in the lower right
Step 5:
When the next page loads, the top will need the target AOS type and license passphrase of the MM where the licenses will be migrated to. By default, all licenses tied to that serial are selected. Chose to migrate them all, or just specific licenses.
Click ‘Transfer’ in the bottom right.
Step 6:
When completed, the final page will load with all the new license keys. These license can be installed only on the respective MM
  • Once we get the license  key, install it on the respective MM.
  • These license cannot be Added to Managed Device if it not controller specific license.
To view the license on the MM use the following command
(Aruba-MM) [mynode] #show license
License Table
Key        Installed               Expires(Grace period expiry)  Flags  Service Type
J6kL3BzQ-jLSyTL+/-ByJi+BPc-lvsEDKkd-kQV6VQ3r-XA/aZ5QT-YyOQH4Xz-I4ZcLHxp-e4DQ96Z9-5G8  2017-01-17 11:48:23[1]  2017-02-16 11:48:23            E     Next Generation Policy Enforcement Firewall Module: 32
z0nFTS4c-rUkHnyRJ-qHpJtdPK-GXdL2UCL-UcyGGnuw-YxzkCJS3-jvbmSxL+-cbzSFZlj-MNAEvYz/-NEQ  2017-01-17 11:52:11[1]  2017-02-16 11:52:11            E     Access Points: 32
WRMlRsMO-h3qbtQCg-bXUGQ06r-yy6l91EM-wlTG3upv-RvIkZTTD-eve4Zsxl-lHe8sZbE-GnOn775l-6/M  2017-01-17 11:53:10[1]  2017-02-16 11:53:10            E     MM: 32
YnUvN6cV-XG4p+ssF-+tUU3/HZ-bUvIBMYe-16pT+F7r-15xwzZRg-NSK2GM1Q-P+DuYd/m-KerLxXDC-jWg  2017-01-17 11:53:28[1]  2017-02-16 11:53:28            E     RF Protect: 32
DnFg4EUB-n0cvvgjI-AE8qt08E-k02qDrZs-lOW0Qqew-7vwavvVR-xvjMxigm-W6ntamAI-Gw5vGHCP-XcM  2017-01-17 11:54:57[1]  2017-02-16 11:54:57            E     VMC: 32
jGgl+NLl-MVifMjVq-JMVpusWw-xL4O9seI-PPQUQ2Yv-HHDKLBV0-kkmarJTn-1yUE91Sa-eK+rZETx-Il8  2017-01-20 13:02:58[2]  2017-02-19 13:02:58            E     WebCC: 32
License Entries: 6
Flags: A - auto-generated; E - enabled; S - Subscription; R - reboot/activation key required to activate; D - Not enabled on license client
Note: Time under 'Installed' for Subscription licenses is the license generation time.
(Aruba-MM) [mynode] #show license debug
Summary of licensing state
Centralized Licensing: Enabled
Switch Role: Master
License Role: License Server
Switch IP: 10.17.164.179
Version history
Revision #:
1 of 1
Last update:
‎03-20-2017 02:14 PM
Updated by:
Comments
JGames
Will this also work to transfer a license from and existing 7220 being RMA to a new 7220?
